Dear All,
I try to get most precise information from my ASI 290MM camera. However I got some troubles with pixel values manipulation. Hope you can help.
According to many sources, Unity Gain for it is 110, what means at 110 Gain 1 electron = 1 ADU.
Camera is 12 bit, so it have 4096 possible values for each pixel, however data are represented by 32 bit integers in range 0-65520.
QUESTION 1: What is ADU in this case: a pixel value of (0-65520) OR sensor value (0-4095) ?
Using SDK one can read following camera fixed informations:
ElectronsPerADU = 3.584
Offset_HighestDynamicRange = 10
Offset_UnityGain = 18
Gain_LowestReadNoise = 300
Offset_LowestReadNoise = 75
QUESTION 2: If at UnityGain 1 electron = 1 ADU then what it means ElectronPerADU = 3.584? Is this value valid at any single specific Gain? If yes - which one?
QUESTION 3: If the electrons to ADU conversion factor is changing with Gain, what is formula for it (or diagram to estimate)?
QUESTION 4: could you please explain data: Offset_HighestDynamicRange, Gain_LowestReadNoise, Offset_LowestReadNoise and especially Offset_UnityGain.
Notice: User can set "Brightness" (Offset). Even if set to 0 actually pixel value is always at least 16 (which correspond to sensor value = 1). For offset 1 and 2 average pixel value is still close to 16. Starting from offset value of 3 until 240, pixel value is equal (offset-1)*16 (with small variations of course).
QUESTION 5: How camera apply Gain and Brightness (Offset)? Which one is first: Offset or GainEg.
result = (value+offset)*gain
OR
result = value*gain+offset ?
Notice: Even if image is highly saturated you will never get pixel value greater then 65504. Seems the real camera range is 1 - 4094 what correspond to pixel values 16 - 65504.
QUESTION 6: is there any mathematical formula converting electrons, gain, brightness (offset) into pixel value?
I found following could be an approximation:
PixelValue = Round( (TrueElectrons/ElectronsPerADU + Max(X+Offset;1) ) * 16
where X is between -0.5 and -0.85. The formula seems not to be good enough and I have no idea how to apply Gain.
Regards,
Gajowy
