Hello, i just want to know if the Asiair device can be connected or is compatible with a CGX-L goto mount.
many thanks in advance
EP
I use ASIAIR with a CGX-L. Everything works finel except Track on/off. You can set Track to "Off", but you can never get it on again with the APP. You have to put it on again with your hand controller.
bsfstreef wrote: I use ASIAIR with a CGX-L. Everything works finel except Track on/off. You can set Track to "Off", but you can never get it on again with the APP. You have to put it on again with your hand controller.
Thanks for your feedback. We'll check this issue.
