I have a 1600MM-Pro Cooled that gets saturated, vertical white lines (every 6 pixels) when hardware binning is enabled. Unbinned it looks normal.
Any ideas on what is causing this?
Additionally: It is a brand new camera, all drivers and SDK updated to latest versions. Happens in ASICAP and SharpCap when Hardware Binning is turned on, and not when binned by software.
Please send a email to support(at)zwoptical.com.
upload a dark frame, *.fit format, on dropbox. and send us link in email.
We will check the images and contact with you. Thank you for feedback.
I've returned it to the vendor and got a replacement.
Not only you many people face the same, but few know how to do this, so I suggest you go D-link Support for help, here you can find all solution which you really want to need.
Thank you guys, our engineer will check this probelm.
Hi ALL,
Sorry for this problem, it is a Firmware Problem. We already known and solved it several days ago.
You can send an email to our support email: support(at)zwoptical.com.
We will help you to update the firmware to solve this problem.
Thanks
Chad
