Hi,
I have just begun using my new ZWO EFW Mini. It works very well so far, but I have one concern I would like to ask you about:
The stepper motor depends on shaft friction with a rubber ring mounted on the filter wheel, for activation. Can you say anything about how well this will work at low temperatures (around 0 degrees C)? Most rubbers will be hard and stiff at temperatures like this!
Thank you very much,
James
