Hi Chad,
This is my standard configuration:
From the USB2 port on my computer, I have a 5m active cable that connects to a 4 port USB2 Powered Hub.
The 1600mm-c camera is connected into the hub. I have the 120mm-s connected into the 1600mm-c USB port.
I also have the ZWO filter wheel connected to the 1600mm-c camera. The 120mm-s is connected to the ST4 port on the mount.
The programs I am using are SGPro, APT and PHD2, Latest versions on all software packages..
In the test I also tried the following.
From my computer I ran a 5m active cable to the 1600mm-c camera, and from another port ran a separate 5m active cable to the 120mm-s camera. the filter wheel was connected to the 1600mm-c. The computer only has USB2 Ports.
Also,
This is not conclusive, as I did not do a recheck. I notice the 1200mm-s could be binning in 8bit mode. When I did a refocus on the scope I noticed the star field got closer and the stars become a bit pix-elated. PHD2 was set to Bin 1.
I hope this helps.
Regards
Robin
