Here's my setup:
iOptron CEM25 mount, Stellarvue SV102T scope with a Stellarvue 50mm guide scope.
The ASI120MM mini is plugged into the Guidescope and is in focus. The ASIAIR can see and control the camera no problem.
ASIAIR is plugged into the CEM25 mount with the USB-Serial cable (not using the ST4 port).
The mount is level and has been polar aligned, and the scope aligned with a 3 star alignment. GOTO is working with objects appearing in the field of view.
I have had two problems on successive evenings:
Error message "Alert: Calibration computer RA/Dec axis angles that are questionable"
Error message "Alert: Your Max RA Duration setting is preventing PHD from making adequate corrections to keep the guide star locked. Increaset the Max RA Duration."
I also got this last message in term of the Max Dec Duration.
I have increased the Max RA and Dec durations from the default 500ms to 1000ms, 2000ms, and 2500ms. I keep getting error message.
Any help, most appreciated!
