Sean.Wang wrote:
120, 224 have same back focal length with 178. I'm sure the lens can be used on all of them.
Sean,
According to the specs online the 120 and 224 are 12.5 backfocus and the 178 MM Cool is 17.5 backfocus. The screw in all sky lens doesn't seem to work, at least not at close range objects with the 178 MM Cool but does focus (I'm talking a coupe of feet away) with the 120 and 224. I just double checked the specs here on the site. The 178 worked fine when I connected it to my 60mm guide scope and focused on a more distant object.
Are you saying that the small All Sky lens should also focus with the 178 at an object a couple of feet away?
Thanks in advance..
Jay S.
