Experiencing a problem with my ASIAir giving even remotely accurate go-to's when connected to my new Explore Scientific iEXOS-100 via serial cable, using the PMC-Eight telescope setting. I know the mount works fine via ASCOM drivers as the go-to's are accurate when using Cartes du Ciel. Was wondering if it might be a incorrect time setting or something like this. My lat/long position are correct in the app but I do not see any place to set time; I assume that it automatically syncs from the phone (iPhone). It appears that maybe my mount is off by about 3.5hrs, (the mount thinks its 3.5 hrs later then the actual time) which is the difference between local time and UTC at my location. Is there somewhere to adjust this setting? My time is showing as correct on my phone. I have tried it on my iPhone, iPad, and Android Tablet and all three have the same issue. I don't think it's the mount because when connected to my PC via ASCOM it works just fine. This leaves me to believe that its a problem with the app/ASIAir and this particular mount (PMC-Eight). I think it might be a bug as I know that there are not many of these mounts around yet. Like I said, it seems that the mount thinks that its 3.5 hrs later than local time, which would actually be UTC time for me (so if its 8 pm, then the mount slews to positions for objects as if it was 11 pm)
