Hello everyone,
In October 2018 I bought a 1600MC Pro (brand new still in box with shrink wrap and seal unbroken) from a seller on Astromart.
I have just begun to have the time to use the camera and I have noticed something weird that is on the sensor when I take flats. It is an oily or "wet" looking pattern on the top right of the Flats. Below is an image of 100 stacked, and very stretched Flats. I debayered the Master Flat to really show the pattern. It is also noticeable in the lower left portion of the image. These were sky flats with t-shirt, 15,000 target ADU, 0.11 sec. Oh, and I only use a field flattener and I removed it and just had the camera connected to the scope so that I could rule that piece out and it still showed up.
Upon further investigation I took care to examine the glass cover over the sensor and then the sensor itself and finally I saw it. It is actually on the sensor!! It is hard to see unless you hold it just right but it's there. Below are two images: One that shows a closeup of the sensor with inverted colors to make it easier to see. And one with the Flat overlayed with transparency turned down. It matches
Sensor with inverted colors. Look in the blue area in the corner and there is a very light shade difference which is the pattern.
Here is the same image with the Flat overlayed to show where the pattern lines up.
It's an oily substance that got on the chip during production or some kind of moisture from cleaning the chips during production?
I have the emails and images from the seller proving the camera was new and the original box never opened.
What should I do?
