Hi Brian,
Sorry for the problem.
For current, I think it is impossible for our current SDK. For native driver, it is a library. Each application has a library, even all of the library are the same. When you run a application, this library will be loaded into the memory. So if you run 2 application, the library will be loaded 2 times, and they are in different position in the memory. On this point, they are different now. But for the hardware of camera, all of them are correct. Then the problem occurs.
But when we program the next generation of SDK, I think we will consider this problem.
So sorry for the problem again.
Thanks
Chad
