Hi,
First, all the ST4 port of our camera is designed in the same way.
Second, for the holes on the camera side, the line sequence is correct. for the port on the cable side, it is also corrent.
For the shotcut, it is right, just one thing you should take care. It's the front of the port. When you connect it to the camera, you need to turn it around. In other words, if you see it from the back of the port, it will be right.
Thanks
Chad
