Hi Wolfgang,
Confused with your words.
Are you mean if you run the camera for 1.5 hours, during this time, every thing works fine, include cooling. After 1.5h, fan does not work, and temperature raised to 40 degrees, also could not download the images. Am I right?
If I am right, does the temperature changed step by step? Beside, please test it with our software, ASICap. And also take care of your connections.
Usually, if there is a hardware problem of the camera, it will failed at the begining.
Thanks
Chad
