Hi
I've had this camera for a few years and it has performed faultlessly.
However now I come back to using it after the Winter period and find the image is broken into the 'windows blinds' effect.
This is the USB 2 camera used on a USB2 port directly on the server at the end of a 3m cable.
I tested the cable before wiring it into my telescope loom and it was fine.
The high speed setting is set to off
the usb speed s set to low'.The effect happens for all image sizes and both 8 or 6 bit depth.
I connect it to a powered USB 3 hub and while recognised it fails to initialise and return any image.
I brought it indoors to try on my Lenovo Yoga 2 pro laptop. There it fails to return a USB descriptor connected to the USB 2 port with a short USB 2 cable and functions perfectly at 65 fps full resolution in FireCap 2.6 x64 when connected to my USB3 port on the same device, with the same cable.
Any ideas on how to resolve this ? Image of firecap view below. Problem reproduced in ASIcap, sharcap and Firecap.
Server is a quad core AMD Fx running W2KR2 x64 with 8GB ram.
cheers
Mike
