Thanks for the answer Chad!
You are correct, it has an ST4 port instead of the 2*USB2.0. As far as I know it is the very first version of the camera.
This is the behavior I am seeing:
- In Sharpcap with native driver, for exposures less than 0.9 seconds, it drops a lot of frames but still downloads data. For exposures longer than 0.9 seconds, all frames are dropped.
- In SGP with native driver, for exposures less than 0.9 seconds, it seems to work fine, with data. For exposures over 0.9 seconds, it downloads a completely black frame, with no data whatsoever (min, max, median, mean are all 0)
- In SGP with ASCOM driver, for exposures less than 0.9 seconds, it works fine, with data. For exposures over 0.9 seconds it gets stuck on "Downloading......." and never manages to download the frame.
My ASI1600MM-C is plugged into my astronomy PC pretty much all the time, so I could give you TeamViewer access to check if you want.
Thanks you!
Yannick
