chad wrote:
Hi Rodd,
Check your connection. It may have been disconnected during the flip.
Thanks
Chad
No Chad--I am not an idiot. Here are the symptoms I have been imagingfor a year with no problems--none.
I tried a new driver--did not help
I think there is definitely a hardware issue. Here is what happened when I tried
1) Camera connects just fine.
2) at first camera one worked ok--but camera 2--the guider, got stuck on Reading Camera--but it exposed for 5 sec OK. This happened when I told the Maxim to expose camera 2 for 5 sec--not using it as a guider--but exposing as camera 2.
3) I disconnected and rebooted, checked the settings and then the main camera would only take .1 sec subs--even though Maxim reported things like "taking 30 sec sub". BUT--now camera 2 worked ok--it exposed for the duration and could read.
4) I switched cables and checked settings and got the main camera to work--but now the guide camera both as guide camera and as camera 2 would only take .1 sec subs.
5) Finally at the end, the main camera was set to take 6 sec subs, and it would get to 1 sec (the bar would extend to 1) and then all of a sudden it would zip to the end and take a 1.1 second exposure.
I have tried every setting combination I can think of and I can't image. The best I can do is image and guide with .1 second subs.
What should I do?
