Hello all,
My name is Fabio, astrophotographer from Brazil and I'm having trouble with my recently purchased ASI 290MC. The computer recognizes it and Firecapture also but does not have the image, a message says that the "recording failed" and there is no information about the histogram, temperature, USB port, nothing. I have already tested in several versions of Firecapture and the same appears. I tried to use Sharpcapture but the same problem happens, there is no image or information. The camera capture program itself does not work either. I'll send you the Firecapture log file:
Apr 03, 2019 11 AM de.wonderplanets.firecapture.log.Log logInfo
INFORMAÇÕES: Starting FireCapture - lets go....
INFORMAÇÕES: System information
FireCapture Release: v2.5
FireCapture Build: 11
FireCapture Directory: C:\Documents and Settings\Dr. Carvalho\Meus documentos\FireCapture_v2.5
OS: Windows XP
OS Version: 5.1
PATH: C:\Documents and Settings\Dr. Carvalho\Meus documentos\FireCapture_v2.5\jre\bin;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Arquivos de programas\Smart Projects\IsoBuster;C:\Arquivos de programas\ATI Technologies\ATI.ACE\Core-Static;C:\Arquivos de programas\Internet Explorer;C:\Arquivos de programas\QuickTime\QTSystem\;C:\Arquivos de programas\Arquivos comuns\Adobe\AGL;.
JRE Version: 1.8.0_45
JRE ClassPath: C:\Documents and Settings\Dr. Carvalho\Meus documentos\FireCapture_v2.5\lib\bio-formats.jar;C:\Documents and Settings\Dr. Carvalho\Meus documentos\FireCapture_v2.5\lib\Firecapture.jar;C:\Documents and Settings\Dr. Carvalho\Meus documentos\FireCapture_v2.5\lib\fits.jar;C:\Documents and Settings\Dr. Carvalho\Meus documentos\FireCapture_v2.5\lib\ij.jar;C:\Documents and Settings\Dr. Carvalho\Meus documentos\FireCapture_v2.5\lib\jacob.jar;C:\Documents and Settings\Dr. Carvalho\Meus documentos\FireCapture_v2.5\lib\jcalendar-1.3.3.jar;C:\Documents and Settings\Dr. Carvalho\Meus documentos\FireCapture_v2.5\lib\jgoodies-common-1.3.0.jar;C:\Documents and Settings\Dr. Carvalho\Meus documentos\FireCapture_v2.5\lib\jgoodies-forms-1.5.0.jar;C:\Documents and Settings\Dr. Carvalho\Meus documentos\FireCapture_v2.5\lib\laf-plugin-7.3.jar;C:\Documents and Settings\Dr. Carvalho\Meus documentos\FireCapture_v2.5\lib\laf-widget-7.3.jar;C:\Documents and Settings\Dr. Carvalho\Meus documentos\FireCapture_v2.5\lib\loci-common.jar;C:\Documents and Settings\Dr. Carvalho\Meus documentos\FireCapture_v2.5\lib\ome-xml.jar;C:\Documents and Settings\Dr. Carvalho\Meus documentos\FireCapture_v2.5\lib\RXTXcomm.jar;C:\Documents and Settings\Dr. Carvalho\Meus documentos\FireCapture_v2.5\lib\substance-7.3.jar;C:\Documents and Settings\Dr. Carvalho\Meus documentos\FireCapture_v2.5\lib\substance-swingx-7.3.jar;C:\Documents and Settings\Dr. Carvalho\Meus documentos\FireCapture_v2.5\lib\swingx-1.6.jar;C:\Documents and Settings\Dr. Carvalho\Meus documentos\FireCapture_v2.5\lib\trident-7.3.jar;
JRE initial heap size: -Xms875m
JRE max heap size: -Xmx875m
Camera: 0
INFORMAÇÕES: Loaded FireCapture.ini
INFORMAÇÕES: loaded library Ephemerides.dll
INFORMAÇÕES: de.wonderplanets.firecapture.util.Ephemerides: loaded library Ephemerides
INFORMAÇÕES: Starting main...
INFORMAÇÕES: Checking cams...
INFORMAÇÕES: loaded library ASICamera.dll
INFORMAÇÕES: loaded library ASICam.dll
Apr 03, 2019 11 AM de.wonderplanets.firecam.ASICam initCam
INFORMAÇÕES: Initialising camera...
Apr 03, 2019 11 AM de.wonderplanets.firecam.ASICam logValues
INFORMAÇÕES: ------------------------------------------------------------------------------------------------------Logging ASICam values - Run #1
Camera model: ZWO ASI290MC
Camera vendor: ZWO Optical
Color: true
Pixel size: 2.9000000953674316
Logging ASICam Exposure values:
Max width/height: 1936/1096
Exposure -> min: 1000 current: 10000 max: 10000
Logging ASICam Gain values:
Gain -> min: 0 current: 200 max: 600
Logging ASICam Gamma values:
Gamma -> min: 1 current: 50 max: 100
Logging ASICam additional controls:
AutoExposure -> min: 0 current: 0 max: 0
Brightness -> min: 0 current: 1 max: 240
WRed -> min: 1 current: 60 max: 99
WBlue -> min: 1 current: 95 max: 99
USBTraffic -> min: 40 current: 80 max: 100
HighSpeed -> min: 0 current: 0 max: 1
SoftwareGain -> min: 0 current: 0 max: 0
AutoHisto -> min: 0 current: 0 max: 0
e/ADU: 3.584
INFORMAÇÕES: loaded library ImageUtil.dll
INFORMAÇÕES: Native: image type: 0
Apr 03, 2019 11 AM de.wonderplanets.firecam.ASICam setROI
INFORMAÇÕES: ROI set to (0,0,1936,1096)
INFORMAÇÕES: PixelSize: 2.9000000953674316
INFORMAÇÕES: Done: Checking cams...
INFORMAÇÕES: starting
INFORMAÇÕES: loaded library Debayer.dll
INFORMAÇÕES: Native: Allocating image buffer
INFORMAÇÕES: Native: buffer size: 2121856
INFORMAÇÕES: Native: starting acquisition
INFORMAÇÕES: Native: image capture failed
Apr 03, 2019 11 AM de.wonderplanets.firecapture.log.Log logError
GRAVE: Image capture failed:
I tried on another computer, tried different USB ports 2 and 3, changed the cables, updated all the softwares and drivers, tried reduce the USB trafic to minimum, tried different operating systems and nothing, always the same error appears. My other cameras work normally, I have an ASI 174MM and an ASI 290MM. Any idea what that might be? Was the camera defective?
Best regards,
Fabio
