Why can't I start my Camera Cooling from ASICAP, I can't find a tool in the program?
The powercable is connected and the led is red. Can you advise me or send me links on Youtube tutorials?
Thank you for your assistance.
Clear sky's.
Arthur Wiegman.
Found it by selecting blue box in the control menu .
Ah!, thanks for that :)
FYI, in the "more control" window, under the "Temp" tab, it says Auti-Dew... should be Anti-Dew, yes?
ricastro wrote: FYI, in the "more control" window, under the "Temp" tab, it says Auti-Dew... should be Anti-Dew, yes?
Yes, it should be Anti-Dew. It's a bug, we will fix it next version.Thank you.
Hi,
I can control the cooling in Asicap ( Planetary) via the 3 dots ( more controls), but in the DSO module of ASIstudio, I only see a temperature setting, but no control to set cooler ON. In the img ( DSO) mode the cooler shows OFF. How to set cooler on in DSO mode?
Thanks!
Love Zwo ASI !!!
Disregard my question. I just found out there is a checkbox in front of "Cooler"...stupid me!
BR,
Erwin
That's good.
Thank you for your feedback.
