Hi ZWO Support,
I ran the FWUpgrde tool on Windows10 to upgrade the Firmware of my ASI 120MC. I used the file "ASI120MC-compatible.iic", then the FWupdate tool gave an error message when "Downloading Firmware". The camera is not recognized anymore on any PC, but when I plug it in Windows makes a sound.
Looks like it's soft bricked. The USB Device Viewer reports it as an Atik USB 2.0 HR Chemi Camera (A). I also use an Atik camera on my laptop.
I saw this:
https://bbs.astronomy-imaging-camera.com/viewtopic.php?t=6854
It's exactly my case. See below the result from Microsoft's USB Device Viewer debug tool
Can you help me please?
How can I re-flash the ASI120MC?
many thanks
Sergio
: Atik USB 2.0 HR Chemi Camera (A)
Is Port User Connectable: yes
Is Port Debug Capable: no
Companion Port Number: 0
Companion Hub Symbolic Link Name:
Protocols Supported:
USB 1.1: yes
USB 2.0: yes
USB 3.0: no
Device Power State: PowerDeviceD0
---===>Device Information<===---
ConnectionStatus:
Current Config Value: 0x01 -> Device Bus Speed: High (is not SuperSpeed or higher capable)
Device Address: 0x02
Open Pipes: 0
*!*ERROR: No open pipes!
===>Device Descriptor<===
bLength: 0x12
bDescriptorType: 0x01
bcdUSB: 0x0200
bDeviceClass: 0xFF -> This is a Vendor Specific Device
bDeviceSubClass: 0xFF
bDeviceProtocol: 0xFF
bMaxPacketSize0: 0x40 = (64) Bytes
idVendor: 0x04B4 = Cypress Semiconductor
idProduct: 0x8613
bcdDevice: 0xA001
iManufacturer: 0x00
iProduct: 0x00
iSerialNumber: 0x00
bNumConfigurations: 0x01
---===>Full Configuration Descriptor<===---
===>Configuration Descriptor<===
bLength: 0x09
bDescriptorType: 0x02
wTotalLength: 0x00AB -> Validated
bNumInterfaces: 0x01
bConfigurationValue: 0x01
iConfiguration: 0x00
bmAttributes: 0x80 -> Bus Powered
MaxPower: 0x32 = 100 mA
===>Interface Descriptor<===
bLength: 0x09
bDescriptorType: 0x04
bInterfaceNumber: 0x00
bAlternateSetting: 0x00
bNumEndpoints: 0x00
bInterfaceClass: 0xFF -> Interface Class Unknown to USBView
bInterfaceSubClass: 0xFF
bInterfaceProtocol: 0xFF
iInterface: 0x00
bLength: 0x09
bAlternateSetting: 0x01
bNumEndpoints: 0x06
iInterface: 0x00
===>Endpoint Descriptor<===
bLength: 0x07
bDescriptorType: 0x05
bEndpointAddress: 0x01 -> Direction: OUT - EndpointID: 1
bmAttributes: 0x02 -> Bulk Transfer Type
wMaxPacketSize: 0x0200 = 0x200 max bytes
bInterval: 0x00
bLength: 0x07
bEndpointAddress: 0x81 -> Direction: IN - EndpointID: 1
bInterval: 0x00
bLength: 0x07
bEndpointAddress: 0x02 -> Direction: OUT - EndpointID: 2
bInterval: 0x00
bLength: 0x07
bEndpointAddress: 0x04 -> Direction: OUT - EndpointID: 4
bInterval: 0x00
bLength: 0x07
bEndpointAddress: 0x86 -> Direction: IN - EndpointID: 6
bInterval: 0x00
bLength: 0x07
bEndpointAddress: 0x88 -> Direction: IN - EndpointID: 8
bInterval: 0x00
bLength: 0x09
bAlternateSetting: 0x02
bNumEndpoints: 0x06
iInterface: 0x00
bLength: 0x07
bmAttributes: 0x03 -> Interrupt Transfer Type
wMaxPacketSize: 0x0040 = 1 transactions per microframe, 0x40 max bytes
bInterval: 0x01
bLength: 0x07
bInterval: 0x01
bLength: 0x07
wMaxPacketSize: 0x0200 = 1 transactions per microframe, 0x200 max bytes
bInterval: 0x01
bLength: 0x07
bInterval: 0x00
bLength: 0x07
bInterval: 0x01
bLength: 0x07
bInterval: 0x00
bLength: 0x09
bAlternateSetting: 0x03
bNumEndpoints: 0x06
iInterface: 0x00
bLength: 0x07
bInterval: 0x01
bLength: 0x07
bInterval: 0x01
bLength: 0x07
bmAttributes: 0x01 -> Isochronous Transfer Type, Synchronization Type = No Synchronization, Usage Type = Data Endpoint
bInterval: 0x01
bLength: 0x07
bInterval: 0x00
bLength: 0x07
bInterval: 0x01
bLength: 0x07
bInterval: 0x00
