Hi,
Would it be possible to enhance the ASCOM interface so that Gain and Offset can be set programmatically without having to disconnect the camera (and setting manually ? This feature would be particularly useful for programs that don’t interface to the native driver.
Many thanks
Robert
Hi Robert,
Not sure what you mean.
Do you mean you want to control the gain in the way you control the exposure? For the current, ASCOM do not have this interface, so for the gain and the offset control, you need to call our dialog to set it. When you call our dialog, there is no need to disconnect the camera.
Thanks
Chad
a month later
Hi Chad,
Thanks for the reply. I found this on the ASCOM site:
https://ascom-standards.org/Help/Developer/html/P_ASCOM_DriverAccess_Camera_Gain.htm
Does this mean that control of gain is indeed available via the ASCOM interface or that ZWO have not implemented that particular property ? If not implemented then are there any programs that use ASCOM and do set the gain by another means or is the ASI driver the best/only option to do this.
Many thanks
Robert
4 days later
Hi Robert,
Understand it this time.
So I think I made a mistake. For gain, yes, we implemented it in our ASCOM driver. And you can use the Set/Get interface to control it.
Thanks
Chad
Write a Reply...
