There appears to be a smudge on the protective glass window of my new ASI 183MM camera.
Can you please confirm that the appropriate replacement protective glass window for an ASI 183MM camera is the ZWO D32 AR protect window?
Also, are there instructions about window replacement?
Thank you for your assistance!
There are instructions for cleaning, which includes disassembly, here;
https://astronomy-imaging-camera.com/manuals/How_to_clean_ASI_camera_and_redry_the_desiccant.pdf
Also, for the Protect Window;
"ZWO D32 AR protect window
Technical Parameter:
Diameter: 32mm
Type: AR window
Thickness: 2mm
Flatness: 1/4 λ
Match Model:
ASI1600 series, ASI294 series, ASI183 series."
So that should be the one. :)
Thank you,Chuckwagon.
You're welcome. Happy to help whenever possible. :)
