Jiang xian sheng,
It looks like the RST-135 USB port failure is not related to the disconnects that I see from ASIAIR (iOS, ASIAIR Beta v1.2). There seems to be still a GOTO bug.
When I perform a GOTO from ASIAIR (e.g., GOTO Vega), the RST-135 mount successfully moves to Vega. However, all communications between ASIAIR and the RST-135 USB port is lost from that point onwards.
At that point, I cannot even shut down ASIAIR in the ASIAIR Settings window.
Interestingly, if I now connect the RST-135 (without rebooting it) USB port to a Windows machine, ASCOM thinks that the RST-135 is working.
I next tried to force quit the ASIAIR app on the iOS device (iPad Pro, iOS version 12.3.1), then relaunched ASIAIR app, but it will still not connect to the Rasberry Pi.
Without touching the mount, I next performed this sequence
- force quit ASIAIR app in iPad,
- powered the ASIAIR Raspberry Pi off,
- powered Raspberry Pi back on,
- connected to ASIAIR WiFi and relaunched ASIAIR,
After this, ASIAIR app now works. It connects successfully to the RST-135 mount (without repowering the mount), and it even shows where the mount is pointed (in my test, Vega. I am doing this in the daytime, so the camera is just seeing the wall of my room :-).
It looks like with the RST-135 ASIAIR Beta app on this iPad, the app is hung after a GOTO command from the ASIAIR Telescope window. The mount appears to be OK (as shown when I could reconnect to the mount after I rebooted the Raspberry Pi and relaunched ASIAIR app.
Slewing the mount using the direction keys does not cause the same disconnect problem. Only the GOTO Object function in the ASIAIR Telescope window has a problem.
Is there some log in the Beta release of ASIAIR that I can send to your development team to track this problem down?
- chen
(陈谷)
