Hi,
in the ASIair app I have to enter the connection parameters
(Ethernet, IP address, port number, UDP) each time the
ASIair is powered on.
I am using the ASIair with a Skywatcher AZ-EQ6 and a Skywatcher
Wifi Module. First I turn on the mount and make a two star alignment,
then I enter the connection Data and everything is fine.
When the ASIair is turned off it looses all the connection
data and I have to re-enter it again the next time I use it.
Is there a way to make the ASIair keep the data?
Thank you
Markus
