Dear Kagaya,
I hope the ST-4 solution works for you until we can fully control the RST-135 through ASIAIR.
Here is additional information that may help you further:
Since RST-135 crashes with ASIAIR, I have been testing the RST-135 indoors (still cloudy here) through ASCOM - StellariumScope - Stellarium (even using a WiFi connection on the handcontroller) and I found that I can wirelessly control the mount from a Windows Surface Pro computer from Stellarium's planetarium.
So, you can still do everything wirelessly, but in addition to a tablet to talk to ASIAIR, you also need a Windows computer to talk to the RST-135. You can still guide by connecting the guide camera in the ASIAIR to the RST-135 ST-4 port. Additionally, you cannot sync the mount to a plate solution from the ASIAIR main camera.
To use ASCOM wirelessly, you will need to change the Communications menu in the handcontroller to use WiFi. Obtain the WiFi password from the handcontroller's WiFi Status window. The RST-135 should then appear as an Access Point (192.168.5.1) that Wndows can connect to.
The RST-135 ASCOM driver is available at the RainbowAstro web site.
If you need help with StellariumScope, the following web page may be helpful:
https://www.lightvortexastronomy.com/tutorial-setting-up-an-equatorial-mount-on-ascom-with-eqmod-stellarium-and-cartes-du-ciel.html
Like GPS, the WiFi antenna is inside the Hubo-i hand controller. It appears to use WiFi Channel 1 on 2.4 GHz and the range is at least 10m from the handcontroller.
Since the mount is not connected to ASIAIR, you cannot take advantage of the ASIAIR plate solving, but you can center a star that is close to your DSO target in the ASIAIR main camera by using the direction buttons on ASCOM or the handcontroller, and then Sync the star with Stellarium. You can then use Stellarium to GOTO the nearby DSO object.
Using two computers is definitely very clumsy compared to using ASIAIR alone to do everything. Before the RST-135, I used ASIAIR plate solve with a Takahashi EM-11 mount, and I am spoilt by how easy and fast it is to acquire an object with the ASIAIR.
But at least using ASCOM-WiFi-Stellarium can help save some trips to use the handcontroller at the telescope to perform a GOTO from the handcontroller.
By the way, I had earlier mentioned that with an iPad, I could connect to the ASIAIR with the RST-135 USB port connected to the ASIAIR, and be able to slew, change slew speed, change tracking mode, etc. -- the ASIAIR program crashed only when I tried to perform a GOTO from ASIAIR. I later tested with a Samsung Tab A, and ASIAIR crashed immediately into Android once I tried to select the RainbowAstro mount.
- chen
