ZWO: is it possible to add the Minimum Move (MnMo) parameter of PHD2 to the ASIAIR Guide Settings window?
For mounts with very slow periodic error, such as the Avalon M-zero, and also strain wave gear mounts like the RainbowAstro and Hobym mounts, better guiding can be obtained by using a smaller MnMo value than the default value (0.15 pixel) that is used by PHD2.
When "seeing" is very poor, a larger MnMo than the default is also useful to prevent chasing "seeing."
Regards,
