Hi Chris,
I am currently running v1.2 Beta 6 (firmware 2.60) on an iPad.
I just tried using an image of the polar region that is displayed on a laptop which is placed about 25 feet away from a 71mm Borg telescope with a ASI178MM camera. (It is daytime here in Oregon, and it is fully overcast, anyway; necessitating a synthetic testing setup.)
The Beta ASIAIR successfully plate solved in 3 seconds with 16 detected stars, starting with a main camera focal length initially set to zero.
Perhaps you can try setting the focal length parameter in the Main Camera Settings window to 0mm, and give it another try. That will force ASIAIR to search through a range of focal lengths, not just one specific focal length. It takes longer than when the focal length is known, and once it successfully solves, ASIAIR will change that number to the true focal length which it derives from the plate.
If that is not successful, you can also submit your plate image to astrometry.net and let it find the FOV, and from there, solve for the true focal length of your system -- see if that focal length is substantially different from the one that you have currently set in ASIAIR.
For what its worth, ASIAIR successfully plate solved when the focal length number in my Main Camera setup window is 10% off, but failed when the focal length is 15% off from the true value.
Clear skies,
