Further to my last reply, I've been playing around today with the Files on the SD CARD to try and get to the bottom of my issue with why I can't use the ETHERNET port on my ASIAIR.
The BOOT FOLDER specifically was my interest as thats the only partition that I can see on a windows machine just by simply mounting the SD CARD.
I am using another PI install (BOOT folder) for my reference....
I backed up my current ASIAIR SD CARD and then decided to see what was different between the ASIAIR install and another PI install.
I cleared the BOOT folder from the ASIAIR, leaving just the cmdline.txt, config.txt, zwoair_license file and the image folder.
I copied the overlays folder, all the bcm27XXX.dtb files, the fixupXXXX.dat files, the startXXX.elf files and kernelXX.img files to the ASIAIR and booted it up..with ta HDMI cable connected so I could see what was being output. Granted, there were some errors , but the ASIAIR booted up fine and low and behold the ETHERNET PORT is working now.
I started the application on the android up and also to my surprise, it shows as connected to my wireless 5GHZ n/ac wireless connection (it wasn't doing so before) and the APP shows its Ethernet is connected (YAY!!!) and has got a DHCP IP address.
The app is also now and again popping up a message "failed to find words", which doesn't affect the functionality, but not sure what it means...
There is a caveat though... When I disconnected my ethernet cable; I wasn't able to connect the APP back to the ASIAIR, until i reconnected the cable, so depsite the ETHERNET working now in tandem with my 5GHZ n/ac wireless connection, the 2.4GHz connection doesn't seem to work now.
I've reflashed the ASIAIR now with my backed up SD IMAGE and I'm back to where I was when I started this:
connection to SSID ASIAIR_XXXXX DIRECT working
connection over WIFI STATION MODE (2.4GHz) working
WIRED ETHERNET showing Not connected.
