1) Leave the ASI224 in place
2) Perform the PA
3) Select and go-to target
4) Swap ASI224 for my DSLR
5) Focus DSLR
6) Program DSLR intervalometer
7) Begin autoguiding
8) Begin capturing with DSLR
Does this sound doable?
2) Perform the PA
5) Focus DSLR
When you are done with polar alignment, switch your guide camera back as the ASIAIR's "guide camera."
If your guide scope is aligned with your main OTA, you can use the guide scope to do plate solving too.
That way, you won't accidentally move the tripod while physically swapping cameras.
One other thing that you can try, if you have an extra spare OTA. Don't need to be sophisticated -- a second "guide scope" would do. Tell ASIAIR that this other OTA and the ASI224 is your main camera. But don't AutoRun, and instead use your intervalometer. Do your polar alignment and plate solving using this secondary OTA. Think of your DSLR and current OTA as piggy-backing on an ASIAIR based system.
Clayhaus wrote:Thank you for the reply… I ended up following the workflow that I had detailed and that operationally worked fine. I wonder if there’s any possibility that ZWO will develop the interface between the air pro and other DSLRs like Sony and Pentax?
We are going to add more DSLRs and MLs support in v1.5. When the public beta is ready, you can try.
Hi. I have the same "problem" and would be very happy if pentax will be supported some day. I can also understand that you have other priorities due to the small market share of pentax. Is there a possibility to use the Asiair as "dumb" shutter control via the small 2.5mm adapter (the "DSLR"-labeled socket)? So without the nice features like plate solving and live pictures, just the exposure plan? Thank you :-)
Plus one one adding Pentax DSLR support! That would be great!
It is November 25, 2023 and still no news about a support for PENTAX K1-II? Please!
That reply is over 3 years old.. and still no news for Pentax users?
