Hi;
I tried hard to write this problem in the equipment list in facebook, but I get an error and everything gets erased....
ASI1600 or ASI2600
Color wheel, focuser, ASI AI PRO
Vixen VC200L
Vixen mount with Starbook 10 (new SDX2).
All works great except the meridian flip.
1- The meridian timing and actual move is OK.
2- BUT when the tracking resumes, it is confused each RA and DEC signals are reversed. I tried to click the flip button but its still wrong.
The same occurs when I calibrate on a target WEST. than I move to a EAST target, when I try to track. the stars runs away. Signals are reverse and I need to re-calibrate.
So, for now. I need to wake up a few minutes before the flip. once the flip occurs. I need to cancel the Autorun manually select the target under preview and re-calibrate the tracking and resume the Autorun...
I would really appreciate if you could fix. I love your products and own it all. keep up the good work.
Michel
