Javier_Covancho If you selected "RAW" when capturing images or videos, the output will appear black and white because the data is saved in an unprocessed Bayer format. You'll need to apply debayering in post-processing to recover the color.
If you want to keep the original data for advanced processing, you can debayer it later using software such as ASIStudio ,Siril
If you'd prefer to get color images directly, simply uncheck the "RAW" option when capturing. The software will apply debayering automatically, and the resulting files will be in color—though the file size will be larger.
