I'm new to my equipment, ASIAIR Pro, EQ6-R Pro, and had a chance to get some imaging in last night. I'm using the Synscan Wifi dongle to connect to the ASI as the USB port direct to the mount will not work at all. Updated to 1.5.1 yesterday. When I use USB to Synscan controller, the mount switches latitude from W to E and obviously causes my goto function to be unusable. Anyway, initial setup last night was fine, PA, guiding, etc... started my autorun session and got 12 subs before meridian flip. After the flip, I spent an hour and a half trying to resume the session. At first, the guiding never resumed. I managed to start guiding again but it quickly wandered off target. I had to restart the session which wasn't a huge deal but I seemed to get into a loop of not being able to image when guiding started, and then guiding would not maintain. This was all with dithering off. I then started over, enabled dithering, and the guiding was much worse. I suspected my issues were due to a wireless communication issue between the ASI and the Synscan wifi. At first i thought I was doing something wrong but after reading the above, I feel like I'm on the right track. I also have an EQmod cable that arrived today so I will try it next time we have clear skies. Also, I don't get why I can't use the USB port on the mount to connect to ASI. I've tried EQmod, 115,200 baud, every possible power on sequence, it will not detect the mount. PC detects the mount no issues so I know my USB ports and cables are good.
