diomedes That is what I was afraid of.
The "71" of the William Optics GT71 is its aperture, not its focal length.
If you are not using a reducer, the focal length of the GT71 is around 420mm. If you use a reducer, the focal length will be reduced by the factor of the reducer, assuming your back-focus is precisly set.
It is best to let ASIAIR determine the focal length for you by setting to focal length to zero (yes, zero). The first plate solve will take a little longer, but once it plate solves and find the actual focal length, ASIAIR will use that number and subsequent plate solutions will be rapid.
