jfletcher When is ZWO going to release a fix for this?
It is now February 2023 , and ZWO has finally claim (read on) that they have increased the upper limit of the EAF steps to 600000 in the ASIAIR v2.1 beta. (yes, I had carefully counted the number of zeros :-).
The January 18 v2.1 Beta (build 9) release notes says there is a need to update the firmware of the EAF (written as "EFA firmware" in the release notes, but it is likely just because no one proofread the notes carefully). However, the latest firmware at ZWO's site is still stuck at 3.3.5, so I have no idea what the real story is.
FWIW, with the latest EAF 3.3.5 firmware that is available at the ZWO FW Update web site, the ASIAIR Focuser settings still won't let me raise the EAF limit to above 60000. So, practically, the same situation right now as back in November 2020.
I also have no way to test if the EAF can slew that 600000 steps at higher speeds. At the original stepping speed, it would take a looong time to slew 600000 steps.
Seriously ZWO, if you ask customers to help beta test the software, at least make sure all the components are there for us to test with. At this point, I am no longer going to test the EAF, since my refractors don't need the extended reach. Someone else can monitor this situation.
