@asiair@zwo#41858 This is the log from an example of horrible guiding. It was going then i had to stop. This is the restart. As you can see guide interval is 1 second but interval in logs is up to 10 seconds.
Guiding Begins at 2020-11-28 03:17:53
Dither = both axes, Dither scale = 1.000, Image noise reduction = none, Guide-frame time lapse = 0, Server enabled
Pixel scale = 3.09 arc-sec/px, Binning = 1, Focal length = 250 mm
Search region = 50 px, Star mass tolerance = 50.0%
Equipment Profile =
Camera = ZWO ASI120MM Mini, gain = 80, full size = 1280 x 960, no dark, no defect map, pixel size = 3.8 um
Exposure = 1000 ms
Mount = EQMod Mount, connected, guiding enabled, xAngle = 76.1, xRate = 1.175, yAngle = -13.9, yRate = 2.161, parity = +/-,
X guide algorithm = Hysteresis, Hysteresis = 0.100, Aggression = 0.500, Minimum move = 0.200
Y guide algorithm = Resist Switch, Minimum move = 0.200 Aggression = 50% FastSwitch = enabled
Backlash comp = disabled, pulse = 0 ms
Calibration step = phdlab_placeholder, Max RA duration = 1300, Max DEC duration = 1300, DEC guide mode = Auto
RA Guide Speed = 7.5 a-s/s, Dec Guide Speed = 7.5 a-s/s, Cal Dec = 4.3, Last Cal Issue = None, Timestamp = Unknown
Dec = -59.6 deg, Hour angle = -3.93 hr, Pier side = West, Rotator pos = N/A
Lock position = 1176.197, 218.323, Star position = 1176.419, 218.230, HFD = 3.22 px
Frame,Time,mount,dx,dy,RARawDistance,DECRawDistance,RAGuideDistance,DECGuideDistance,RADuration,RADirection,DECDuration,DECDirection,XStep,YStep,StarMass,SNR,ErrorCode
INFO: SETTLING STATE CHANGE, Settling started
1,1.257,"Mount",0.153,-0.173,-0.131,0.190,0.000,0.000,0,,0,,,,3182,36.86,1
2,2.183,"Mount",0.521,-0.325,-0.191,0.584,0.000,0.000,0,,0,,,,3032,36.02,1
3,4.087,"Mount",0.345,-0.495,-0.398,0.454,-0.179,0.000,153,E,0,,,,3098,36.09,1
4,5.186,"Mount",0.423,-0.265,-0.156,0.474,0.000,0.000,0,,0,,,,3441,38.01,1
INFO: SETTLING STATE CHANGE, Settling complete
5,6.265,"Mount",0.611,0.001,0.147,0.593,0.000,0.000,0,,0,,,,3278,37.60,1
6,9.552,"Mount",0.759,-0.125,0.061,0.766,0.000,0.383,0,,177,S,,,3223,37.10,1
7,18.772,"Mount",0.333,0.208,0.282,0.273,0.127,0.137,108,W,63,S,,,3514,38.68,1
8,23.861,"Mount",0.551,-2.765,-2.552,1.196,-1.142,0.598,972,E,277,S,,,3177,37.18,1
9,35.347,"Mount",-2.735,-2.656,-3.234,-2.021,-1.513,-1.010,1288,E,467,N,,,3130,36.69,1
10,42.417,"Mount",-2.178,-0.948,-1.442,-1.888,-0.725,-0.944,617,E,437,N,,,3283,37.85,1
11,48.457,"Mount",-2.087,0.751,0.228,-2.206,0.066,-1.103,56,W,510,N,,,3039,36.15,1
12,57.248,"Mount",-0.570,-0.764,-0.878,-0.370,-0.392,-0.185,334,E,86,N,,,3452,38.73,1
13,59.920,"Mount",0.697,1.353,1.481,0.354,0.647,0.000,551,W,0,,,,2982,35.99,1
14,65.476,"Mount",0.954,-0.054,0.177,0.940,0.000,0.470,0,,217,S,,,3034,35.85,1
15,69.200,"Mount",0.943,-0.215,0.017,0.967,0.000,0.483,0,,224,S,,,3116,36.80,1
16,78.043,"Mount",0.276,-0.482,-0.402,0.383,-0.181,0.191,154,E,89,S,,,3102,36.18,1
17,87.201,"Mount",0.618,0.779,0.904,0.413,0.398,0.207,339,W,96,S,,,3181,36.79,1
18,90.396,"Mount",-0.315,-0.298,-0.365,-0.235,-0.144,0.000,123,E,0,,,,3490,39.06,1
19,91.448,"Mount",-0.349,-0.380,-0.453,-0.248,-0.211,0.000,180,E,0,,,,3418,38.56,1
20,93.857,"Mount",-0.406,-0.210,-0.301,-0.344,-0.146,0.000,124,E,0,,,,3218,37.17,1
21,99.882,"Mount",-0.264,1.312,1.211,-0.571,0.538,0.000,458,W,0,,,,3061,36.50,1
22,102.480,"Mount",-0.014,-0.366,-0.359,0.074,-0.135,0.000,115,E,0,,,,3212,37.08,1
23,111.399,"Mount",0.406,0.676,0.753,0.232,0.332,0.116,283,W,54,S,,,3088,36.31,1
24,115.879,"Mount",0.540,-0.306,-0.167,0.597,0.000,0.299,0,,138,S,,,3343,37.91,1
25,129.890,"Mount",-1.027,-0.303,-0.541,-0.925,-0.243,-0.463,207,E,214,N,,,3195,37.11,1
26,139.403,"Mount",1.447,1.320,1.628,1.089,0.721,0.545,613,W,252,S,,,2960,35.95,1
27,146.458,"Mount",1.501,-1.149,-0.756,1.733,-0.304,0.866,259,E,401,S,,,3344,37.66,1
Guiding Ends at 2020-11-28 03:20:20
Guide log for the night is attached
