janx
how are the RASA fans managed? temp based?
Does your doc provide max amp used?
Your cam cooling should be fine, as normally you should set the temp to keep cooling under 80% load (weak point of ZWO cams)
You should be fine normally...
Rule of thumb, most mount would pull 1.5 to 2.5 amps during fast GoTo (AMF), then less than 1 amp during guiding.
EAF negligeable
