The support pages claim: "This bracket is designed to work with C8, C9, C11 and C14 the Celestron SCT scopes. You can directly connect it to the scopes without using the feather touch focusers." This seems to describe my scope, but there is a connection problem. I even purchased two different bracket kits, hoping one would work.
I will attempt to fabricate an "adapter plate" from a large metal WASHER to account for the mismatched holes. If it works, I will let you know. You maY WISH to include something similar in future kits. thank you.
