Would like to eliminate SynScan hand controller and will need to connect ASI Air Pro through EQ Mod cable to Sky-Watcher EQ6R-Pro mount. There are three potential sites to connect from the ASI Air Pro RJ45 Ethernet Port (if that's the right one to use) to the mount.
Sky-Watcher Mount options. 1) Hand Controller -- RJ-45 8-pins outlet
2) Auto Guide-- RJ-12 6-pins outlet
or a newly added 3) USB poearchedrt Type B
Have search internet with no comments on the newer Sky-Watcher mount.
Recommendations?
Thanks,
Joe
