ashutoshv I don’t mind trying the 2.0 beta version if there is some way to downgrade to stable version on iOS devices.
The Beta apps that are downloaded through iOS TestFlight can simply be deleted, and then dowloading the released iOS app from the standard iOS App Store. (You can even download different versions of the current Beta.)
However, if you want to run older apps, be sure that you have a way to also revert back to older ASIAIR firmware after the Beta app replaces the released firmware with the beta firmware. With the first two generations of ASIAIR, that means to make a firmware backup that you can restore from, or you will be wating hours trying to download 20 GB of data from the internet.
