brianboyle If if I were to put on a spacer the adapter ring is now stuck fast to the filter drawer body.
By the way, if you are looking for metal spacers, AgenaAstro has some.
I don't know what the hole size is for the ASI2400, but Agena has the Blue Fireball brand (Blue Fireball's other stuff are pretty good, too) metal washer spacers for M54. The worst thing I have come across is the Baader one-time use Delrin spacer (I suspect ZWO's might be Delrin too), but I am not sure Baader even has the 54mm size.
I have an ASI6200, and an ASI2600 which was converted to an M54 tilt plate, so I run M54 pretty much everywhere nowadays.
