Hello:
I bought a ZWO ASI462MC a couple of weeks ago. It's my first camera and I have this problem:
The camera body was closed, but not completely screwed in, so when trying to remove the lens, the entire body was unscrewed.
Once done, I noticed that the protective window has a circular scratch just below the edge of the hole in the front of the camera itself. Since it's just under the edge, I suppose it won't affect the pictures I can take, but I'm not entirely sure.
Also, I think the problem is that the body of the camera rubs against the glass when closing it; that's why I don't know if I should screw it on completely, because I'm afraid it will break.
I do not know if it is something that is typical of this type of camera or is that, for whatever reason, mine has a problem.
It seems that this window is sealed to the O-ring, so I don't know how it could be replaced with a new one if necessary.
Thank you.
