Hi:
I wonder if anyone has successfully connected the CEM40G to the AAP? I see much success with CEM40, but what about the CEM40G?
I recently brought a CEM40G, and it can't connect to AAP. I try to connect using the RS323 USB cable. I also try using a straight USB cable, neither of them works. The AAP is running on the latest version. The CEM40G is also running the latest firmware.
I can successfully connect the CEM40G to PC using a straight USB cable, this is how I update the firmware on the CEM40G. I can connect other mount (Sirius EQ-G) to the AAP. So I don't know the issue is with the CEM40G or AAP.
Does anyone have any suggestions?
Thanks
Andy
