Thanks for those inputs. I think the ASI294MM 2.3 micron pixel mode might work well for lower focal length scopes below 500mm. I have an ASI294MC Pro and the 4.63 micron pixels work well with my ES127 952mm scope. I also have an Edge HD 9.25 and some consider the 4.63 micron pixels too small for its native focal length of 2350mm because it results in an image scale of about 0.4 arc seconds per pixel. Binning the ASI2600MM 2x2 to get 7.5 micron pixels might be a better fit for 2350mm, (image scale = 0.66 arc sec/pixel). For the filter wheel, I was hoping I could replace the inner wheel with the 7 position 36mm wheel and save on the motor, electronics and housing if I went with the 2600MM.
What do you think about the value of the 16 bit ADC for the 2600MM vs the 14 bit ADC for the 294MM?
