astrosatch
1 Stop tracking before MF - set the time as the above reply
2 After MF, ASIAIR will try to re-center the target, so it's based on the plate solve function, since you are using the NB filter, try to increase the Auto-Center EXP time plz.
3 If the MF final finished, the AutoGuiding will start then you won't get trailed stars.
