Byrdsfan1948 Hello Chen, I would be very happy to try that if you wouldn't mind telling me how???? :-)))
Do a Google search on how to access a Samba server with your computer.
On macOS and Linux, it is simply a matter of using the network to connect to smb://192.168.1.123 (the actual IP address is what your router has assigned to the ASIAIR). Raspbian (the OS that ASIAIR uses) has a built in Samba file server.
You can use the GUI in macOS by selecting the Go item in the Main Menu of the Finder and choose "Connect to Server...". Then simply type in the address as above (the "smb" identifies the type of server), or let the Go dialog browse for all connected file servers on your home network. The ASIAIR will be one of them.
While you are at it, go to your router and change the ASIAIR DHCP address to a fixed, reserved address. This way, each time you try to access the ASIAIR on your network in the future, it will be available at the same fixed address.
Furthermore, in the ASIAIR network setup window, you can give your ASIAIR a distinct name (in case you have more than one; or you take the ASIAIR out to a remote site that has other people using ASIAIR). My four ASIAIR (two v1, and two current models) each have its own name and fixed address at home. If you don't do that, the ASIAIR will append part of its serial number to the string "ASIAIR_" and use that as the device's name -- which makes it difficult to figure out which is which.
When you open the network volume, you log in as guest. You will see two items, one is "Disk" (the microSD card) and the other is named Udisk (for USB flash card or SSD). Pick the one that you were using in ASIAIR while autoguiding and you should find the PHD2 logs in there (the logs disappeared between ASIAIR v1.5 and v1.5.3, but is back).
