Byrdsfan1948 I am now wondering about my Samsung Galaxy A Tablet?
Autoguiding is done autonomously inside the ASIAIR (Raspberry Pi), Al. Your tablet is simply displaying the results; it is not part of the feedback loop. The lag time is too great (and with the ASIAIR WiFi, too unstable) that you will get overshoots exactly like what you are seeing, but it will happen all the time, instead of creeping up on you.
The next time you have the wild oscillations, instead of rebooting the ASIAIR, could you please try this? First stop autoguiding (red stop sign), go over to the Guide Setup and disconnect the guide camera. Wait half a minute and reconnect it back. Unfortunately, at this point, I think that ASIAIR will also make you recalibrate guiding. Then resume autoguiding to see if the problem goes away. If it does then we will have some concrete evidence that it is the guide camera process that is the culprit (binary chop to find the bug :-).
I have for some time been suspecting that there is something bad that happened to their guide camera interface since the frame rate of my PHD2 log has become more erratic in the past few ASIAIR releases. If the frame rate stutters, and your mount has enough backlash, we will see the oscillatory behavior; albeit I don't know if the PHD2 itself compensates for the non-constant sampling times.
I haven't myself experience large errors like what you are seeing, with my mount. I am assuming that your aggressiveness settings are already below 0.5, right?
When all else fail, try this:
Use the plate solve and GOTO as usual to get to your target. Then, disconnect ASIAIR's Telescope Setup from your mount and instead select "On-Camera ST4." You would also need an 1-to-1 RJ11 cable to go between the guide camera's RJ-11 and your mount's ST-4 input.
Then go through the guide calibration process.
This then bypasses the pulse guiding. Check back on my post in the past 2 mounts, I had described how pulse guiding through the mount protocol works (ASIAIR uses slew commands to generate the pulses). If there is any lag time in the ASIAIR mount interface (USB serial port), it can also cause the overshoots that you observed.
If ST-4 guiding is clean, then the error is in their USB driver (I will send an email to the ZWO developers to ask them to check the lag time too -- some guy might have thought that mount control does not need high priority, but it actually needs very high priority to do pulse guiding properly, since the guide pulse lengths are done with software timing. ST-4 does not use the USB serial protocol and will not suffer this lag -- (but it may suffer some other lag, ha ha).
