Flats. With my SBIG STF8300m taking a flat using the Red Filter I was able to obtain an ADU of 35K in 4 seconds but with the ASI 1600 Pro it takes 30 seconds to obtain a flat of 26K.
The STF8300 was using a scope of F10 while the scope I'm using with the ASI 1600 Pro is F6.
Am I incorrect to assume I should of been able to obtain a ADU of 25K in a shorter time?
The Gain is not set to anything, and in the ASCOM Properties the Gain is 0.
