Hi GooE,
Thank you for the reply. Im in the same boat - for my wide field OTA I have a home-made mount bracket. I agree the ASI does seem to PA and plate solve quite well, but what I'm getting at, and maybe it's more academic than practical, is that the ASI is essentially aligning the OTA with the pole...not so much the mount if in fact the mount's polar scope is not perfectly aligned with the OTA/camera sensor. Even though you physically adjust the mount's dec and RA axis against what the ASI is "seeing" you're not really getting the mount perfectly aligned with the pole, and that is essentially the whole point of a PA. So it's not going to be that accurate if the OTA is not centered with the mount's polar axis....again that's just a thought and maybe Im off...in the end I seem to have relatively good success when auto guiding, but I have an Orion Atlas mount, not the most fine-tuned machine in this hobby so an accurate PA is important especially if I use my ES127 scope.
