Hello,
I am running the latest X2 plugin for Mac on your web site, downloaded earlier today.
Here is the version info:
Note that the version info shows that the Mac X2 plugin is using ASI SDK V1, 15, 0915. The SDK change log on your web site says that the first SDK version that supported unlocked bin1 mode was 1.16. Your Windows version screenshot shows the SDK version as V1, 16, 3, 0.
For the Mac X2 plugin is the ASI SDK linked into the X2 plugin binary x2cameraASI.dylib? I do not see the separate SDK binary libASICamera2.dylib anywhere in TheSkyX directory tree or anywhere on the Mac on which I am running TheSkyX so I assume this means that the ASI SDK is linked directly into the X2 plugin. If that is the case then the Mac X2 plugin needs to be relinked with the newer SDK that supports the unlocked bin1 mode.
Please have the developer responsible for the Mac X2 plugin look into this.
Thanks,
Dan Carlson
