Kring so not enough to account for entirely otherside of planet - so to answer your thought there, delta from actual home to AAP home does not account for why it pointed where it did.
OK, I will poke around some more.
So far, with the simulator, I have not yet seen a failure with "Sync and GoTo" yet. Interestingly, when Sync and GoTo is pressed, ASIAIR sends my mount (the simulator) a Star Sync command (the center of the solved plate in ASIAIR), followed by a GOTO.
GOTO in RST-135 is done using three steps. You first send it the RA of the target. You then send it the declination of the target. Finally you send it a "slew to target" command.
Now, here is the funny part: if I do a manual "Sync Mount" from ASIAIR, and then a manual GOTO from ASIAIR, I get the exact sequence as I do when I use "Sync and GoTo." And yet, last night for me (and most of the time for you), a "Sync and GoTo" gave a "below horizon" error, while the manual sequence will work! They can't come from the same code path.
Since I haven't been able to provoke the problem when simulating the RST-135, I decided to switch to simulating the CGX (the mount in your video).
Immediately, I notice that once connected, ASIAIR tells me my longitude is E 237º 11' , while my longitude is W 122º 48'. They are the same angle as you go around the 360º circle from Greenwich, but I am going to some further tests now to see what is actually happening with this bug (which also has been floating around for more than a year now, with no resolution).
For what its worth, when ASIAIR connects to the mount, it sends the local latitude and longitude (which it gets from the tablet's OS) to the mount. Next, it send UTC offset and Local Time. I am currently on Daylight Saving Time (UTC offset for PDT is -7) and when I was watching, the time was 8:39 PM local time. As expected, since ASIAIR does not understand DST, ASIAIR sets the mount to UTC offset -8, and local time 19:39 (i.e., both are Pacific Standard Time values, instead of Pacific Daylight Time). Both should resolve to the correct Local Sidereal Time, so there should not be a problem as long as the DST flag in the mount is also turned off. But why ASIAIR does this Rube Goldberg exercise instead of obeying time specifications (a single "DST" switch) is beyond me.
Anyway, I am now going to take a short digression to check out the East/West longitude bug while I have the CGX simulator running.
Oh, by the way, ASIAIR does require that your mount is Homed when first connecting. Upon connecting to my CGX simulator, ASIAIR flashed this alert on the (iOS) tablet:
"The mount must be turned on at Zero Position and did the one Star Align."
