stevesp they don’t appear in my AAP driving AVX
As I responded to you in the other thread which you had started about this issue (autoguide rate), ASIAIR does not use the AutoGuide rate from the NexStar AUX commands. Please check the threads that you had started.
For the NexStar protocol, ASIAIR uses the standard slewing commands to perform autoguiding, with slew rate set to 1x sidereal rate.
There is no autoguide rate to pick. It is always 1x for your mount.
The current ASIAIR v1.5.3 displays a window (when you are using the NexStar protocol, and probably the SynScan protocol too since they are identical - same Chinese company) with a "set to 1x" button in case your slew rate is currently set to some higher rate like 256x (which surely will eventually crash the OTA train into the pier).
ASIAIR only uses the NexStar protocol's Guide Rate (Sidereal, Solar and Lunar only, King rate is not available in SynScan/NexStar) in the NexStar AUX protocol. This is different from the AutoGuide Rate of the AUX protocol, that lets you set the auto guide rate to any integral percentage of sidereal rate.
1x autoguide rate is a bit too rough, especially when coupled with the latency of using 9600 baud, if you ask me. Any backlash, and you will start undamped motion even with aggressiveness turned way down.
I have seen ASIAIR issue guide pulses of just 4 or 5 milliseconds, while each character in the command sequence at 9600 baud itself takes 1 millisecond (and there are many characters for the complete start/stop slew commands). Those commands either undershoot or overshoot the correction by a lot.
