rueffy Say Chen, you said before that the ASIAIR Plus doesn't send any hemisphere information to the CGX mount.
When the ASIAIR sends the time and location to the mount, it sends the wrong sign.
However, that is done only once, when the ASIAIR first connects to the mount, as long as you never Sync to the mount.
So, you can connect the ASIAIR to the mount (at which point it sends the wrong coordinate), then with the mount's hand controller, revert the hemisphere to the correct one, and go from there.
There is also Beta version (Beta for some two years now) of the mount driver in ASIAIR that does send time and location information to the mount. You can select that version, as long as you enter the correct time and location manually with the mount's hand controller.
